You can create short, easy-to-type links for flyers and business cards using a URL shortener.
This tool transforms your long, complex website address into a much shorter version.
A service like Linko, for example, can instantly generate a simple link that is perfect for printing, making it easier for people to visit your page.
The Problem with Long Links in Print
When you print a full website address on a business card or flyer, you force people to manually type it into their browser.
A long URL like https://yourbrand.com/products/summer-collection/details?id=123&source=flyer is difficult to type correctly.
Any small mistake will lead to a “page not found” error, and you will lose a potential customer.
A short link solves this by being both brief and memorable.
How to Create Your Short Link
You have two great options for creating a short link, depending on your needs.
For a Quick, One-Time Link
If you need a short link right away without any setup, you can use a free tool.
Find Your URL: First, copy the long website address you want people to visit.
Shorten It: Next, go to the Linko free link shortener and paste your long URL into the provided field.
Copy and Print: Click the button to shorten it. Your new, compact link is now ready.
- You can copy it and give it to your designer to add to your flyer or business card.
For Custom, Branded Links
To make your link even more professional and easy to remember, you can customize it.
A custom link like onlylinks.cc/specialoffer looks better and builds more trust than a random string of characters.
Create an Account: Start by signing up for a free Linko account. This allows you to customize your links.
Make a New Link: In your dashboard, paste your long destination URL.
Add a Custom Alias: Look for the field labeled “custom alias” or “custom back-half.”
Here, you can type in a relevant word or phrase. For instance, if the link goes to your portfolio, you could use “
my-work.” -
Shorten and Use: Shorten the link, and it’s ready for your print materials.
With a free Linko plan, you can create up to 50 custom short URLs, which is ideal for tracking different printed campaigns.
