What is WordPress?
WordPress is a popular content management system (CMS) that allows you to easily create and manage websites.
It’s widely used for blogging, business websites, portfolios, and more, thanks to its flexibility and user-friendly interface.
What is a WordPress plugin?
A WordPress plugin is a software add-on that extends the functionality of your WordPress site.
Plugins can add new features, improve performance, or integrate third-party services, making it easy to customize your website to fit your needs.
How to get the Linko WordPress plugin?
The Linko WordPress plugin allows you to effortlessly shorten-link using a simple shortcode within your WordPress site.
Here’s how to get it and set it up:
Navigate to the Tools & Integration section,
Then find WordPress Integration.
Download the plugin file from there.
In your WordPress admin dashboard, go to Plugins > Add New > Upload Plugin.
- Select the plugin file you downloaded, named
linkshortenershortcode.zip, and click Install Now.
After uploading, activate the plugin. It will appear in your plugins list as “Link Shortener Shortcode.”
How do I shorten links using shortcode?
Once the plugin is activated, you can shorten links directly within your posts or pages using the shortcode [shorturl].
To shorten a URL:
[shorturl]https://google.com[/shorturl] -
You can also use the shortcode in HTML:
<a href="[shorturl]https://google.com[/shorturl]">Google</a>
No configuration is needed.
The Linko WordPress plugin is designed for ease of use.
Once activated, it’s already configured to work with your Linko account, so there’s no need for additional setup. All shortened links will be automatically saved in your Linko account.
Important note
Please note that the Linko WordPress plugin is only available to users with access to the Developer API.
Additionally, be cautious about sharing this plugin, as it grants full API access to your Linko account.
By using the Linko WordPress plugin, you can seamlessly integrate link shortening into your WordPress site, enhancing your content management and streamlining your workflow.
