The current CSV import process is quite burdensome if mapping Channel and Campaign are important to you. The manual work compounds with more links. Let me explain. As is, after I import these CSV links, I need to find them in My Links, manually select each one, and then click the button to assign them to a Channel or Campaign. Once that process is done, the links you had selected are no unselected so you have to manually select them again to do the other process - assign to a Channel or Campaign.
I can see the danger of allowing the Channel or Campaign into the CSV file but this could be resolved by forcing the user to manually map the CSV fields to the UI ensuring and confirming everything is going to import as wished.
Thank you.
