A CTA (Call to Action) message is a small, persuasive pop-up that prompts users to take action, like visiting a product page or completing a specific task.
You can customize the CTA message to align with your brand or campaign and easily embed it on your destination website.
A demo of CTA Message - Screenshot taken from MiniTools.me website.
Steps to create a CTA message:
Step 1: Name your CTA
- Choose a name for your CTA. This is only for your reference and won’t be visible to visitors.
Step 2: Upload a logo or image
- Use a square logo (maximum size: 100×100) to prevent distortion.
Ensure the file name has no spaces (e.g., “custom-image-name.png”).
To remove an image, click the upload field and cancel it.
Step 3: Write your custom message
- Keep your message under 140 characters to ensure it fits within the pop-up.
Step 4: Add an overlay label
- This is optional. If used, it should be 5 to 7 characters long. Leave it empty to disable.
Step 5: Enter your destination link
- Provide the URL where you want users to be directed.
Step 6: Enter call-to-action (CTA) text
- Write compelling text for the button that encourages users to click.
Step 7: Customize appearance
- Choose colors for each part of the overlay to match your branding.
Step 8: Choose overlay position
- Select where the pop-up will appear: bottom left, bottom right, top left, or top right.
Step 9: Click the Create button
- Once everything is set, click Create to finalize your CTA message.
This clear and simple process allows you to create a professional, branded CTA message that engages users and directs them to your desired action.
- CTA message demo URL: https://my.linko.me/CTA-Message
Check out this guide on how to assign (choose) a CTA overlay while shortening a link.
