Note
Although this integration is tailored for Zapier, but it is flexible enough to be used with other webhook systems like Pabbly and Activepieces.
This means you can connect Linko with various platforms to automate tasks across different tools.
Integrating Zapier with Linko enhances your ability to automate workflows, keep track of important events, and ensure your processes run smoothly without manual intervention.
What is Zapier?
Zapier is a powerful automation tool that connects different apps and services, allowing them to work together without the need for coding.
By setting up “Zaps”—automated workflows that trigger actions in one app based on events in another—you can streamline your processes, save time, and ensure that tasks are handled efficiently.
For example, you can automatically create tasks in your project management tool when a new email arrives, or update a spreadsheet when a new sale is made.
How to integrate Zapier with Linko?
Integrating Zapier with Linko enables you to automate tasks and receive important notifications through webhooks.
This setup allows Linko to send real-time updates directly to Zapier, so you can trigger automated actions whenever specific events occur, like creating a new short URL or when someone clicks on one of your links.
What you can automate with Zapier webhooks
By connecting Linko to Zapier, you can automate the following notifications:
URL creation notification
Every time you create new short URLs using Linko, a notification is sent to your Zapier webhook.
This can trigger workflows in Zapier, such as updating a database, sending an alert, or creating a new entry in another tool.
Click notification
When a user clicks on your shortened URL, Linko sends a notification to your Zapier webhook. This allows you to track engagement, automate follow-up actions, or update analytics automatically.
Steps to add your Zapier webhook URLs (endpoints).
Navigate to Zapier Integration: Log in to your Linko account and go to the Zapier Integration section.
Paste Your Webhook URLs: Paste the webhook URLs provided by Zapier into the designated fields. These URLs will serve as endpoints for Linko to send notifications.
Save and Test: After pasting the URLs, save your settings. Run a quick test to ensure that the integration is functioning correctly.
