What is bookmarklet?
A bookmarklet is a small tool that you can add to your browser’s bookmark bar.
Unlike a regular bookmark that just saves a website link, a bookmarklet performs a specific action when clicked.
With Linko’s bookmarklet, you can instantly shorten the URL of any webpage you’re currently viewing, saving time and effort.
It’s a convenient way to shorten-link without needing to open a separate tab or tool.
How to shorten a link using bookmarklet?
Using Linko’s bookmarklet tool, you can quickly shorten URLs of the websites you visit.
If you’re logged into your Linko account, the shortened links are automatically saved for future access.
URL shortener bookmarklet is available for free on all pans, including the free plan.
Here’s how to add the bookmarklet to your browser’s bookmark bar:
Go to the Tools section in your Linko account.
Click on the bookmarklet option.
Drag the bookmarklet link and drop it into your browser’s bookmark bar.
- While browsing, click on the bookmarklet to instantly shorten the URL of the current webpage.
Alternatively, you can manually add the bookmarklet to your bookmarks bar by copying the link from your account and adding it to your browser’s favorites.
Note: For websites using SSL (https), some widgets might not pop up due to security restrictions. In such cases, you’ll be redirected to the Linko site where you can view your shortened URL.
Using the bookmarklet makes shortening links easier and faster, streamlining your workflow while ensuring all your links are stored in your Linko account for future use.
