How many CTA overlays can I assign per short link?
You can assign one CTA overlay per short link. However, you are free to use the same CTA overlay on multiple individual short links.
Can I assign two CTA overlays to a single short link?
Yes, technically, it is possible to assign two CTA overlays to the final destination URL, though the process requires a few extra steps.
  1. First, assign your initial CTA overlay and shorten the link.
  2. Then, copy the shortened URL.
  3. Shorten the already shortened URL that you copied and assign the second CTA overlay.
This method allows you to apply two CTA overlays to a single short URL.
