What is Quick Shortener?
Quick Shortener is a fast and simple way to shorten URLs without needing to open a separate tool or extension.
This method allows you to shorten a link directly by adding a specific prefix to the webpage URL you want to shorten. It’s a great alternative for quickly shortening links while browsing.
How to shorten a link using Quick Shortener?
With Linko’s Quick Shortener, you can easily shorten URLs by following these steps:
Go to the Tools section in your Linko account.
Click on Quick Shortener to get the required prefix.
Save or remember the parameter:
/q/?u=. -
Add the Quick Shortener prefix: Use the link
https://linko.me/q/?u=as a prefix at the beginning of any URL you want to shorten.
For example, if you want to shorten https://www.google.com, you would enter:
https://linko.me/q/?u=https://www.google.com
Once you add the prefix and visit the new URL, the link will automatically be shortened.
By using the Quick Shortener feature, you can instantly shorten links while browsing, making the process faster and more convenient.
