What is a CTA overlay?
A CTA overlay is a pop-up or banner that encourages users to take specific actions, such as signing up for a newsletter, participating in a poll, or redeeming a coupon. It is a powerful way to capture user attention and drive engagement.
What is the targeting feature?
Targeting allows you to display different content based on specific user characteristics, such as their geographic location (Geotargeting) or the device they are using (device targeting). This ensures that your message reaches the right audience in a personalized way.
Can I use CTA Overlay redirection with Geotargeting?
Yes, you can combine a CTA overlay with smart routing and targeting features like Geotargeting or device targeting.
This ensures that the right overlay appears to the right users based on their location or device type.
Steps to use CTA overlays with Geotargeting:
Create your CTA overlay: First, design and create your CTA overlay to match your campaign goals.
Set up Geotargeting or device targeting: After creating the CTA overlay, configure Geotargeting or device targeting to ensure the overlay reaches users in specific locations or using certain devices.
Select the CTA overlay in the redirect section: Before shortening the link, adjust the redirect method. Change it from “direct” to the CTA overlay you’ve created.
You can follow the same steps for language targeting and IP targeting.
This combination of targeting and Help Center > CTA Overlay will help you deliver more relevant content to your users, improving engagement and conversion rates.
