A campaign groups related short links together so you can see their combined clicks in one place.
Plans: Pro, Business, Agency
What does a campaign do?
A campaign is a private group of links. Only you and your team can see it.
Use one when you want to:
- Keep links from the same promotion together
- See the total clicks for that promotion, not just for each link
- Compare countries, devices and referrers across the whole group
Note: A campaign groups and measures links. It does not change where a link goes, and it does not split traffic between links.
How do I create a campaign?
- Open Campaigns in the sidebar.
- Click Create Campaign.
- Type a name in Campaign Name.
A name is all a campaign needs. There is nothing else to set up.
How do I add links to a campaign?
You can add a link while you shorten it, or add links you already have.
While shortening a link
- Paste your long URL.
- Open the Advanced section.
- Choose your campaign in the Campaign field.
- Click Shorten.
For links you already have
- Open Links.
- Tick the links you want to group.
- Click Add to Campaign.
- Pick your campaign under Select Campaign, then confirm.
To take links out again, select them and click Remove from Campaign.
Every link in a campaign shows the campaign name as a badge on the Links page.
How do I see how a campaign is performing?
The Campaigns page lists each campaign with its Links count and Total Clicks.
For the full breakdown, click Statistics on the campaign row. It shows:
- Traffic Distribution across the links in the campaign
- Clicks Over Time and Hourly Performance
- Countries and Languages
- Platforms and Browsers
- Referrers
Set a Date Range to filter every chart on the page, and click Export Stats to download the data.
How do I rename or delete a campaign?
Open Actions on the campaign row, then choose Rename or Delete.
Note: Deleting a campaign does not delete its links. They stay in your account and are simply no longer grouped.
What if I want to split traffic between links?
A campaign measures links together. It does not send visitors to different destinations.
To send one short link to several destinations, use A/B testing, where you set the percentage of traffic each destination receives. A/B testing is available on the Business and Agency plans.
