Custom Domain Setup Guide
There are two ways to set up your branded domain with Linko, depending on your DNS provider:
Using Cloudflare → Follow Guide A: Custom Domain with Cloudflare
Using other DNS providers (GoDaddy, Namecheap, Google Domains, etc.) → Follow Guide B: Custom Domain without Cloudflare
If you’re already using Cloudflare or prefer their DNS management, follow this guide.
Step 1: Add Your Domain to Linko
Go to the Domains section.
Click Add Domain.
Enter your branded domain.
(Optional) Set up Domain Root and Domain 404 for better visitor handling.
Step 2: Configure DNS in Cloudflare
For a Root Domain (yourbrand.com)
Go to your Cloudflare DNS settings.
Create a CNAME record:
Name:
@or your root domain -
Target:
linko.me -
Proxy status: Proxied (orange cloud)
Important: Do not create an A record with the same host as your CNAME. This causes DNS conflicts and your short links won’t work.
For a Subdomain (go.yourbrand.com)
Name:
go,link, orout -
Target:
linko.me -
Step 3: Configure SSL in Cloudflare
Ensure proxy status is Proxied (orange cloud).
Go to SSL/TLS > Overview.
Change encryption mode from Flexible to Full.
Helpful Cloudflare Links
If you use GoDaddy, Namecheap, Google Domains, Porkbun, Hover, or any other DNS provider, follow this guide.
Linko automatically provisions SSL certificates for your domain.
Click Add Domain.
Step 2: Configure DNS at Your Provider
Log in to your domain registrar (GoDaddy, Namecheap, etc.).
Go to DNS settings.
Host/Name:
@or leave blank (depends on provider) -
Value/Points to:
linko.me -
TTL: Auto or 3600
Log in to your domain registrar.
Go to DNS settings.
Host/Name:
go,link, orout -
Value/Points to:
linko.me -
TTL: Auto or 3600
Step 3: Wait for SSL Provisioning
Linko automatically provisions an SSL certificate for your domain once DNS propagates. This typically takes:
DNS propagation: 5 minutes to 48 hours
SSL provisioning: Automatic after DNS is verified
Check your domain status in Linko’s domain settings. Once it shows Active, your domain is ready.
Glossary
What is a branded domain?
A custom web address (like yourbrand.com) that replaces the default linko.me domain. Branded domains build trust and reinforce your brand with every link shared.
What is Domain Root?
The page visitors see when they visit your domain directly (e.g., yourbrand.com without a short alias). Set this to redirect to your homepage or any page you choose.
What is Domain 404?
The error page shown when someone visits a short URL that doesn’t exist. Customize this to display a branded message or redirect users to a useful page.
What are Logo and Favicon options?
You can customize your short links and client portals with your brand’s logo and favicon:
